[GRASS5] A naive opinion on how grass *should* work
Russell Nelson nelson at crynwr.com
Thu May 2 15:24:47 EDT 2002
Carl Worth writes:
 > Maybe if a display command is given a map which is entirely outside
 > the current region a useful message could be generated informing
 > the user what happened and what could be done to fix it?).
That's an excellent idea.  Tell the user "You asked for a view
entirely off the selected map.  Use d.region rast=map to move the view
onto the location of your map."
 > Then, if a particular command must have a region that it cannot
 > compute from its input, then that command could request that the user
 > specify a region and explain how to do it.
Yup, yup!
-russ nelson              http://russnelson.com | Okay, enough is enough!
Crynwr sells support for free software  | PGPok | Can we PLEASE all stop
521 Pleasant Valley Rd. | +1 315 268 1925 voice | using insecure Microsoft
Potsdam, NY 13676-3213  | +1 315 268 9201 FAX   | email products???
