[GRASS5] [bug #1362] (grass) v.out.shape only can export labeled polygones
Request Tracker grass-bugs at intevation.de
Mon Oct 21 03:40:06 EDT 2002
this bug's URL: http://intevation.de/rt/webrt?serial_num=1362
Subject: v.out.shape only can export labeled polygones
Platform: GNU/Linux/i386
grass obtained from: CVS
grass binary for platform: Compiled from Sources
I want to export digitized polygons from GRASS 5.0 wich are not labeled. The v.out.shape module is from the actual CVS. I always get the output" memory error". After making some tests with labeled and unlabeled polygons, I get the conclusion that this module can only export labeled polygons!
-------------------------------------------- Managed by Request Tracker
