[GRASS5] [bug #1362] (grass) v.out.shape only can export labeled polygones
Silke Reimer silke at intevation.de
Wed Oct 23 03:39:24 EDT 2002
Hello
On Mon, Oct 21, 2002 at 09:40:06AM +0200, Request Tracker wrote:
> this bug's URL: http://intevation.de/rt/webrt?serial_num=1362
> Subject: v.out.shape only can export labeled polygones
> Platform: GNU/Linux/i386
> grass obtained from: CVS
> grass binary for platform: Compiled from Sources
> I want to export digitized polygons from GRASS 5.0 wich are not labeled. The v.out.shape module is from the actual CVS. I always get the output" memory error". After making some tests with labeled and unlabeled polygons, I get the conclusion that this module can only export labeled polygons!
> -------------------------------------------- Managed by Request Tracker
Would it be difficult to improve v.out.shape so that it can export
non labeled polygons from GRASS? The problem is that we have about
300 polygons in one layer and it would be very exhausting to label
all those polygons. Any suggestions?
Thanks,
	Silke
> grass5 mailing list
> grass5 at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass5
Silke Reimer
Intevation GmbH                      http://intevation.de/
FreeGIS                                http://freegis.org/
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20021023/bb59173e/attachment.bin
