[GRASS5] GRASS 5.0.2 released
Markus Neteler neteler at itc.it
Fri Apr 11 10:17:59 EDT 2003
On Fri, Apr 11, 2003 at 03:01:56PM +0200, Bernhard Reiter wrote:
> On Fri, Apr 11, 2003 at 01:26:56PM +0200, Markus Neteler wrote:
> > On Fri, Apr 11, 2003 at 12:00:50PM +0200, Bernhard Reiter wrote:
> > > On Fri, Apr 11, 2003 at 11:25:33AM +0200, Markus Neteler wrote:
> > > > GRASS 5.0.2 is released. Thanks to all contributors!
> > > > This new version comes with a couple of bugfixes.
> Also we should start adding more checksums and gpg signatures on
> released tarballs. This would make later integrity checks possible
> and be proactive against trojaned tarballs.
Sounds good. But I need detailed instructions how to do that...
> You can extract it from the rpm sources from the FreeGIS-CD 1.2.2,
> named grass-5.0.0-1.src.rpm.
Work in progress...
Markus
