[GRASS5] Re: 57 compile error
Markus Neteler
neteler at itc.it
Thu Dec 11 09:56:46 EST 2003
Kirk,
(cc 'grass5')
On Thu, Dec 11, 2003 at 08:25:07AM -0600, Kirk R. Wythers wrote:
> Markus,
> I'm working on the 57 build. The configure options I'm using are:
> ./configure --with-grass50=/Users/kirkw/tmp/grass53_exp_2003_12_06/ \
> --enable-shared \
> --with-includes="/usr/X11R6/include /sw/include" --with-libs=/sw/lib
> --with-tiff-includes=/sw/include --with-tiff-libs=/sw/lib \
> --with-tcltk-includes=/sw/include --with-tcltk-libs=/sw/lib/tcl8.4 \
> --with-opengl-libs=/usr/X11R6/lib
> --with-opengl-includes=/usr/X11R6/include \
> --with-fftw-includes=/sw/include \
> --with-gdal=/usr/local/bin/gdal-config \
> --with-postgres-includes=/sw/include/postgresql \
> --with-postgres-libs=/sw/lib/postgresql \
> --with-odbc \
> --with-motif \
> --with-glw \
> --with-readline \
> --with-freetype
> Then I do a make mix,
> then make. Here is the make error:
> 0.0/execute.o OBJ.powerpc-apple-darwin7.0.0/fetch.o
> OBJ.powerpc-apple-darwin7.0.0/listdb.o
> OBJ.powerpc-apple-darwin7.0.0/listtab.o
> OBJ.powerpc-apple-darwin7.0.0/main.o
> OBJ.powerpc-apple-darwin7.0.0/parse.o
> OBJ.powerpc-apple-darwin7.0.0/select.o -L/sw/lib/postgresql
> -lgrass_dbmidriver -lgrass_dbmibase -lgrass_sqlp -lgrass_dbstubs
> -lgrass_dbdialog -lgrass_gis -lgrass_datetime -lintl -lgrass_datetime
> -lpq -lcrypt -L/sw/lib/tcl8.4 -ltk -ltcl \
> -lz
> ld: can't locate file for: -lcrypt
> make[3]: ***
> [/Users/kirkw/tmp/grass57_exp_2003_12_06/dist.powerpc-apple-
> darwin7.0.0/driver/db/pg] Error 1
> make[2]: *** [subdirs] Error 1
> make[1]: *** [subdirs] Error 1
> make: *** [default] Error 1
Your problem looks like a configure issue.
In ./db/drivers/postgres/Makefile
CRYPTLIB = -lcrypt
is hardcoded. Maybe this should go elsewhere into Platform.make
Markus
