[GRASS5] Re: proj bugs
Paul Kelly
paul-grass at stjohnspoint.co.uk
Fri Jul 4 06:36:55 EDT 2003
On Fri, 4 Jul 2003, H Bowman wrote:
> Ok, got the new do_proj.c but it doesn't seem to be using it.
> How do I rebuild/install a library with rebuilding everything?
> The usual gmake5 from within src/libes/proj/ doesn't seem to do it.
It is a static library so you need to also recompile the individual
modules that use proj, to link in the new version of the library.
