[GRASS5] Re: proj bugs
H Bowman hamish_nospam at yahoo.com
Sat Jul 5 04:15:46 EDT 2003
> > > > g.setproj Segfaults if a datum is already set. If you say "n" to the
> > > > "specify a map datum for this location?" question it works, and you
> > > > can run it again to set a new datum, but if you try and just change
> > > > the transform params it segfaults.
> Turns out it was platform-specific. Ran fine on IRIX but I got the bug
> reproduced on Cygwin.
> And it was my fault as well---while experimenting with using fixed length
> strings and variable ones I must have left in some calls to free() that
> shouldn't have been there and must have been corrupting the memory. Fixed
> in CVS so hopefully should be better now. It is really good to be getting
> all these bugs ironed out.
Ok, changing transform parameters works fine for me now in g.setproj.
Hamish
