[GRASS5] Diffs for grass 5.0.2 package for debian woody now available.
Glynn Clements
glynn.clements at virgin.net
Fri Jul 11 13:48:35 EDT 2003
giuseppe wrote:
> The diff against official grass-5.0.2_src.tar.gz are ready as promised. The
> workstation is up and running and if things hold I hope to answer without
> lag. The grass-5.0.2_src.tar.gz I used today to make the diffs is the same I
> used when making the source debian package. Today I downloaded:
> ftp://grass.itc.it/pub/grass/grass5/source/grass-5.0.2_src.tar.gz
> and made a cmp against my old grass-5.0.2_src.tar.gz to ensure they are the
> same.
> As usually, you can find everything at:
> http://ezralabs.esaurito.net/repository/debian/grass/
> In particular:
> http://ezralabs.esaurito.net/repository/debian/grass/grass_5.0.2-1.diff.gz
Looking at the diff, I have a couple of questions:
1. "configure" has already been run, and lex/yacc source files have be
processed to produce the intermediate C files. Is this due to Debian
policy, or is it an artifact of the way that the package was produced?
2. What was the purpose of this patch:
--- grass-5.0.2.orig/src/display/devices/lib/Text2.c
+++ grass-5.0.2/src/display/devices/lib/Text2.c
@@ -170,9 +170,11 @@
double text_size_x,double text_size_y,double text_rotation,
char *string)
- double sinrot = sin (D2R (text_rotation)) ;
- double cosrot = cos (D2R (text_rotation)) ;
+double sinrot,cosrot;
+ //double sinrot = sin (D2R (text_rotation)) ;
+ //double cosrot = cos (D2R (text_rotation)) ;
+ sinrot = sin (D2R (text_rotation)) ;
+ cosrot = cos (D2R (text_rotation)) ;
am_inside = 0 ;
curx = basex = (double)x ;
cury = basey = (double)y ;
Is this due to a gcc bug?
3. What is the purpose of debian/fixpaths.sh? The entire GRASS
installation (i.e. everything under $prefix/grass5) is supposed to be
relocatable. If the installation is moved, the only thing that should
need to be changed is the definition of GISBASE in the grass5 script.
Glynn Clements <glynn.clements at virgin.net>
