[GRASS5] Diffs for grass 5.0.2 package for debian woody now available.
Glynn Clements
glynn.clements at virgin.net
Sat Jul 12 00:11:22 EDT 2003
Nephero wrote:
> > Looking at the diff, I have a couple of questions:
> > 1. "configure" has already been run, and lex/yacc source files have be
> > processed to produce the intermediate C files. Is this due to Debian
> > policy, or is it an artifact of the way that the package was produced?
> This was an artifact, Federico already pointed this problem, and tomorrow
> I'll see what can be done.
OK. If you don't intend to include these files in the source package,
you should run "make maintainer-clean" to get rid of them. A quick
summary of cleanup make targets, from least to most aggressive:
mostlyclean: removes object files, and a few others.
clean: also removes the libraries, and the staging directories
(basically a local copy of everything that gets installed) containing
the executables.
distclean: also removes the files which are generated by the configure
script.
maintainer-clean: also removes the C files which are generated by
lex/yacc.
> > 2. What was the purpose of this patch:
> > --- grass-5.0.2.orig/src/display/devices/lib/Text2.c
> > +++ grass-5.0.2/src/display/devices/lib/Text2.c
> > @@ -170,9 +170,11 @@
> > double text_size_x,double text_size_y,double text_rotation,
> > char *string)
> > - double sinrot = sin (D2R (text_rotation)) ;
> > - double cosrot = cos (D2R (text_rotation)) ;
> > +double sinrot,cosrot;
> > + //double sinrot = sin (D2R (text_rotation)) ;
> > + //double cosrot = cos (D2R (text_rotation)) ;
> > + sinrot = sin (D2R (text_rotation)) ;
> > + cosrot = cos (D2R (text_rotation)) ;
> > am_inside = 0 ;
> > curx = basex = (double)x ;
> > cury = basey = (double)y ;
> > Is this due to a gcc bug?
> The png driver didn't compile correctly, (but the package was created and
> usable anyway) so I made this little fix and now it seems fine (compiles and
> runs fine). I think the catch was the definition/assignment in the same
> line. I basically just splitted them in different lines. The gcc I used is
> the one bundled with Debian Woody. It doesn't seem to me a gcc bug. Maybe
> Federico or someone else can better answer this question than me. Please
> remember the patch applies to 5.0.2, Silke already pointed out that it's no
> use for the CVS version, that had already fixed this problem indipendently.
There is a known problem with the PNG driver in 5.0.2, caused by the
omission of $(MATHLIB) from the Gmakefile. Your patch includes a fix
to the Gmakefile.
The above patch will have no effect if you have a working compiler
(except that it will cause compilation to fail if the compiler doesn't
support C++ double-slash comments).
Perhaps someone tried the above, then realised that the problem was
actually in the Gmakefile, but left the changes in? Please try it
without the above patch; if it fails, I would like to see the error
message.
Glynn Clements <glynn.clements at virgin.net>
