[GRASS5] Applicant for developing
Thierry Laronde tlaronde at polynum.org
Sun Jul 27 13:27:59 EDT 2003
On Sat, Jul 26, 2003 at 11:02:15PM +0200, Moritz Lennert wrote:
> All available info on 5.1 should be indexed here:
> http://grass.itc.it/grass51/index.html
> For draft 5.1 programming manuals go here:
> http://grass.itc.it/grass51/manuals/
> You should look at the programmer's manual for 5.0:
> http://grass.itc.it/grass5/progmangrass50.pdf
> And for code access, there is the GRASS CVS repository:
> http://grass.itc.it/grasscvs.html
Thanks!
I will have some time in august, so I will hopefully being able to start
some work on small problems I encounter as a user while diving in the code.
Regards,
Thierry Laronde <tlaronde at polynum.org>
Site Debian Francophone (aka SDF) : http://www.debian-france.org/
