[GRASS5] Re: missing mapinfo support
Michael Barton michael.barton at asu.edu
Sun Nov 23 16:26:26 EST 2003
On Saturday, November 22, 2003, at 05:55 PM, Allan Metts wrote:
> A question:  Your "Alternate 2" (converting to a shape file) seems
> much simpler than "Alternate 1" for importing lines and polygons.  Is
> there a downside to doing the shapefile conversion?
Allan,
Not really AFAICT. If you have access to ESRI products, I think this is
the best way to go currently. Remember, for GRASS 5.0.x vector files,
you can only have 1 integer (i.e., cat) and 1 other value (i.e., label:
numeric or string) associated  with each vector file. In a shapefile
import, you need to specify which fields will become cat and label. If
you need more fields, you will need more copies of the relevant vector
file.
____________________
C. Michael Barton, Professor
Department of Anthropology
PO Box 872402
Arizona State University
Tempe, AZ  85287-2402
USA
Phone: 480-965-6262
Fax: 480-965-7671
