[GRASS5] r.terraflow
Laura Toma ltoma at bowdoin.edu
Wed Sep 17 21:11:21 EDT 2003
I am not sure I understand what the problem is.. This is the update
about r.terraflow:
-version 1.4 does not compile with gcc3.2.
-version 1.5 does.
-functionality is the same, some files in 1.5 have changed to gcc3.2
requirements
-the only difference in the Gmakefiles  is that 1.5 contains the
additional compile flag Wno-deprecated
-both versions tar-balls can be found at
http://www.cs.duke.edu/geo*/terraflow/r.terraflow.1.4.tar.gz
<http://www.cs.duke.edu/geo*/terraflow/terraflow-grass.html>
http://www.cs.duke.edu/geo*/terraflow/r.terraflow.1.5.tar.gz
I downloaded grass-5.0.3rc2 and it looks like it contains version 1.4.
Is there a reason for this? If not, it should be updated.  It would be
simpler if I had CVS rights, but I never got around to doing that..sorry.
-Laura
Helena wrote:
> Glynn,
> as I understand it the changes in the Gmakefile were made in response
> to Aleksey's email (see below). The tar-ball that I gave to Markus is
> the one from June that Laura refers to in her message, while the
> version in the CVS is couple months older and supposedly had the
> problem compiling on Mandrake. If the current Gmakefile is better than
> the new one then of course it should stay.
> I am cc this to Laura, hopefully she will be able to advice us on this.
> Helena
> Glynn wrote:
> Don't update the Gmakefile; the one in CVS is correct (well, it isn't
> correct, but it's an improvement over the updated version).
> Laura I. Toma wrote:
>> Dear Aleksey,
>> Thanks for your feedback. I asnwered some of your comments below. We'll
>> try to make the html page clearer.
>> I put a new tar-ball at
>> http://www.cs.duke.edu/~laura/bin/
>> -Laura
>> On Thu, 12 Jun 2003, Aleksey Naumov wrote:
>>> Dear Helena and Laura,
>>> Thank you for the great work on r.terraflow! It seems fast and well
>>> done. I
>>> checked out version 1.5 and here is some feedback.
>>> Ver. 1.5 compiled fine on my Mandrake 9.1 (GCC 3.2.2), with CVS
>>> GRASS, however
>>> I had to do some manual editing. Specifying --with-cxx configure
>>> option was
>>> not enough, I got "Compilation error in module:
>>> src.contrib/DUKE/r.terraflow
>>> (ignored)".
>>> The problem was with file paths in IOStream/lib/src/*.d files which
>>> are set
>>> for a RedHat system. Once I changed redhat-specific paths to their
>>> mandrake
>>> equivalents:
>>>     (a) /usr/lib/gcc-lib/i386-redhat-linux/3.2  =>
>>>         /usr/lib/gcc-lib/i586-mandrake-linux-gnu/3.2.2
>>>     (b) /usr/include/c++/3.2/i386-redhat-linux  =>
>>>         /usr/include/c++/3.2.2/i586-mandrake-linux-gnu
>>> everything compiled ok. I suppose this sort of thing will require more
>>> C++-specific configure checks which probably won't be really needed
>>> until
>>> 5.1.
>> the *.d files in IOSTREAM are generated automatically. my mistake
>> not to clean up before making the tar ball. Should work if you delete
>> them
>> and try compiling again from scratch.
>>> The rest of this is mostly about the HTML document page, with some
>>> general
>>> questions/suggestions...
>>> 1. The "elev" argument is incorrectly documented as "elevin"
>> fixed.
>>> 2. The HTML page seems confusing to me in the part explaining
>>> flooding and
>>> sinks:
>>>     (a) "swatershed" output is described as "output sink-watershed
>>> raster", yet
>>> what it really seems to hold is a map of subwatersheds. Using "sink" is
>>> really confusing here, since it most commonly means a point from
>>> which there
>>> is no outflow (and this is how sinks are described in the text just
>>> above --
>>> as "areas that do not spill out"). Why not call it "watershed" and
>>> describe
>>> as a map that holds small subwatersheds?
>>>     (b) BTW, what controls the size of those subwatersheds saved in the
>>> "swatershed" map? (Something similat to "threshold" in r.watershed
>>> may be
>>> nice...)
>> In Terraflow the watershed of a sink represents the *entire* area that
>> flows into the sink.  Basically each sink-watershed represents a
>> bucket in
>> the ground that will fill with water when it rains (long enough). Each
>> sink-watershed is well-defined, and does not depend on the choice of a
>> threshold. Selecting all the sinks in the terrain and computing their
>> watersheds defines a partition of the terrain into sink-watersheds.
>> In general a watershed can be defined by an outlet point. Depending
>> on how
>> the outlet point is chosen, the  watershed is larger or smaller.
>> r.watershed solves a more general problem of partitioning the terrain
>> into watersheds of arbitrary outlets (not necessarily sinks) and of a
>> given (approximate) size.  The problem is how to choose the  outlets
>> in order to have the watersheds define a partition and have approximately
>> the specified size. This is a different problem that computing
>> flow direction and flow accumulation. r.terraflow does not do that (yet)
>> -- but we are working on extending it with this functionality.
>>>     (c) "Flooding produces a sink-less terrain in which every cell has a
>>> downslope flow path leading outside the terrain ..." -- Does this
>>> mean that
>>> all internal no-outlet subbasins (like catchment of a no-outlet
>>> lake) are
>>> filled in?
>> Depends what you mean by "filled in".  There are 2 options:
>> (1) either water (and thus flow direction) stops in sinks
>> (2) or water escapes the sink by going upslope.  If the water goes
>> upslope, then it follows the lowest path to the edge of the terrain.
>> We think of flooding (filling the sink-watersheds) as a technique for
>> finding  lowest paths and assiging upslope flow directions.  That is,
>> one can assign downslope FD on the flooded terrain and map them back onto
>> the  original terrain. It does not mean that the terrain has actually
>> been
>> flooded.
>>>     (d) I used a float DEM and my output flooded (I think it's
>>> clearer to call it
>>> sinkless or depressionless) DEM is a CELL. Why not FCELL, for
>>> computational
>>> and storage reasons?
>> yes. we did not expect that the flooded terrain would be actually used.
>>> I hope I don't come accross as nagging or unappreciative! You've
>>> done a great
>>> work, I just thought I'd put in my 0.05c :-)
>>> Thank you,
>>> Aleksey
>>> On Monday 09 June 2003 06:54 pm, Helena wrote:
>>>> The new version that compiles under gcc3.2 is at
>>>> I did not have time to try it out and submit it,
>>>> so if you can test this latest version that would help. Also, let us
>>>> know if you
>>>> have any questions - it is still a work in progress.
>>>> Glynn is right that it belongs to the GRASS development version and
>>>> the previous version of r.terraflow is in src.contrib/DUKE
>>>> Helena
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20030917/5054da15/attachment.html
