[GRASS5] v.out.ogr, OVERWRITE=YES
Stephan Holl
sholl at gmx.net
Wed Apr 7 12:08:49 EDT 2004
Dear developers,
after fiddeling around with v.out.ogr writing to a PostGIS-DB I
realised, that it is not possible to "update" an existing dataset in
PostGIS.
ogr2ogr has the -update-switch, which allows to update
datasets with the same name (giving aditionally -lco OVERWRITE=YES).
Would it be possible to add this switch also to v.out.ogr to update
existing datasets in PostGIS?
My workaround is exporting to shape and then using ogr2ogr as written
above, but a straitforward import in PG would be nice too :-)
Thanks for any comments in this.
Cheers
Stephan Holl
btw, are the ogr-driver specific documentations for -lco-parameters in
ogr2ogr somewhere?
Stephan Holl
Check headers for GnuPG Key!
http://www.gdf-hannover.de
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20040407/d5d8b991/attachment.bin
