[GRASS5] zlib and raster rows
Glynn Clements
glynn.clements at virgin.net
Wed Apr 28 11:57:46 EDT 2004
Andrea Antonello wrote:
> I'm trying to read rasters rows through java, but it doesn't always work.
> The rows are compressed one by one through zlib (deflate) and put in the file
> (the header knows where they start).
> The reading works for me if the data is something like
> 10.0 20.0 30.0
> but it can't recognise the compression method when I have something like:
> 10.123 20.321 30.0
> In the code I only found the Z_DEFAULT_COMPRESSION used, so I really can't
> understand what goes on. It should compress always the same way.
> Any hint?
Are you getting an error from the zlib decompressor, or is the
uncompressed data just not what you were expecting?
Glynn Clements <glynn.clements at virgin.net>
