Jaro Hofierka wrote: > The real problem is that the devi option doesn't produce a vector file > with atributes. I don't remember if I fixed this in updated > v.surf.rst[.cv] but it should work for a CV file). I found there just > old code for site format. devi in v.surf.rast is now written as 3D vector (devi as z), in v.vol.rst still missing, -> known BUG in man. Radim
