[GRASS5] [bug #2864] (grass) v.in.ogr fails many times
importing shp files
blazek at itc.it
blazek at itc.it
Tue Dec 21 06:14:47 EST 2004
Send us more details about errors.
> Cannot open dbf database
the database (directory) probably does not exist.
> Another error is a loop about breaking nodes.
Nodes cannot be broken. What is exactly the problem.
Can you provide the files?
Radim
> this bug's URL: http://intevation.de/rt/webrt?serial_num=2864
> Subject: v.in.ogr fails many times importing shp files
> Platform: Mac OSX
> grass obtained from: CVS
> grass binary for platform: Compiled from Sources
> GRASS Version: 2004_12_18
> v.in.ogr fails many times importing shp files.
> This is a big problem because in cvs_2004_09_20 release v.in.ogr worked
> with all files.
> Now I have many problems with many files.
> I have created new empty LOCATION for importing files.
> Same shp files worked with old v.in.ogr but now they go to error or Grass
> exit...
> I always use -o flag (override)
> Only few shp files don't have problems.
> This is one error:
> DBMI-DBF driver error:
> Cannot open dbf database: /myworks/grassdata/myproj_utm33/PERMANENT/dbf/
> Cannot open database '/myworks/grassdata/myproj_utm33/PERMANENT/dbf/'
> Cannot open database /myworks/grassdata/myproj_utm33/PERMANENT/dbf/ by
> driver dbf
> but there are other messages.
> It's impossible to import files.
> v.external works without problem
> -------------------------------------------- Managed by Request Tracker
> grass5 mailing list
> grass5 at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass5
