[GRASS5] can't start mon under WinGeneric but can under X11,
again...
Glynn Clements
glynn.clements at virgin.net
Fri Jan 23 23:11:52 EST 2004
Paul Kelly wrote:
> Partial answers to the GDAL problems:
> 1) If you use the latest CVS version of GDAL it is much more likely to
> support the HDF format you need
> 2) After installing GDAL, compile GRASS using the --with-gdal option. It
> should then pick up the libgdal*.dll properly.
> It would seem that if you don't compile GRASS using the --with-gdal
> option, r.in.gdal simply will not work. --with-gdal is now the default for
> both 5.3 and 5.7.
I suggest that the "bridge" code is removed altogether, and the
--with-gdal switch is changed to behave like the other --with-*
switches, i.e. --without-gdal would mean "don't build r.in.gdal".
Glynn Clements <glynn.clements at virgin.net>
