[GRASS5] GRASS 5.7.0 beta1
Radim Blazek
blazek at itc.it
Thu Jun 3 05:35:31 EDT 2004
On Wednesday 02 June 2004 13:17, Hamish wrote:
> > > One another annoyance is that all the monitors closed down when
> > > exiting. Is this a new feature? I usually just leave monitors
> > > running permanently and if just exiting and restarting quickly to
> > > change location this could become annoying.
> > Yes, new feature:
> > http://grass.itc.it/pipermail/grass5/2004-May/014486.html
> > http://grass.itc.it/pipermail/grass5/2004-May/014528.html
> > I know that it is more work now, I was used to do the same. Maybe
> > it is just question of a habit because now it is possible to start
> > more sessions at the same time. Anyway, I think that the possibility
> > to run (without tricks) more sessions (e.g. scripts in one mapset
> > and interactive work in another) is more important than
> > this inconvenience.
> > We can maybe find a way how to reopen monitors when grass is started
> > in X?
> How safe is this for changing mapsets via g.gisenv? I'm doing that all
> day long. That works with 5.7.0 (+d.redraw), but I don't want to badly
> screw anything up by mistake..
This is not affected.
> I know it's up to me not to have the same mapset loaded twice, but what
> happens if on a bad day I do?
You get wrong outputs. I forgot about this possibility.
> Do I have to add $LOCATION/$MAPSET/.gislock management to my mapset
> changing script? I'm already running $GISBASE/etc/clean_temp upon exit..
Yes.
> Or is this tied to the process id that started it? Upon exiting GRASS
> 5.7.0 I get: ERROR: LOCATION_NAME not set
> but it seems to be ok in ~/.grassrc57
Not clear to me when did you get this.
What about official
g.mapset/g.chmapset/g.set/g.reset/? gisdbase= location= mapset=
which would check if the mapset is in use, reset variables and run d.erase?
This should be in 5.7.0, I think. Otherwise it is too dangerous.
Radim
