[GRASS5] 57 compile error
Markus Neteler
neteler at itc.it
Mon Mar 15 14:55:34 EST 2004
On Mon, Mar 15, 2004 at 11:29:47AM -0600, Kirk R. Wythers wrote:
> That's how I've done it before as well. And tha't how I did this time
> too (on my first try). When that yielded the error, I tried the order
> that was spelled out in the 57 INSTALL file. You know... when something
> doesn't work, THEN read the INSTALL file.
And then, if you find errors in the INSTALL file, please report :-)
Markus
> Kirk
> On Mar 15, 2004, at 11:05 AM, William K wrote:
> >Don't you do the configure BEFORE the make mix? This is how I've
> >always done it. No problems with the 3/13 cvs snapshot this weekend
> >for me on MOSX.
> >On Mar 15, 2004, at 10:17 AM, Kirk R. Wythers wrote:
> Kirk R. Wythers tel: 612.625.2261
> Dept. of Forest Resources fax: 612.625.5212
> University of Minnesota email: kwythers at umn.edu
> grass5 mailing list
> grass5 at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass5
Markus Neteler <neteler itc it> http://mpa.itc.it
ITC-irst - Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18 - 38050 Povo (Trento), Italy
