[GRASS5] 5.3-CVS: RPM created - please try
Markus Neteler
neteler at itc.it
Thu May 13 18:01:56 EDT 2004
Scott,
(cc grass5)
On Thu, May 13, 2004 at 05:35:47PM -0400, Scott Mitchell wrote:
> I am VERY far from being an rpm expert, especially since I've just
... as far as me ... :-)
> returned to one machine with rpm after a few years of dpkg-only
> machines, but for what it's worth, here's what I get on a relatively
> "stock" redhat 8 machine:
> [smitch at bouteloua smitch]$ sudo rpm -i grass-5.3.0-2004_05_08.i386.rpm
> Password:
> error: Failed dependencies:
> gdal >= 1.1.9 is needed by grass-5.3.0-1
> proj >= 4.4.7 is needed by grass-5.3.0-1
This is desired: It suggests to first install GDAL and PROJ
which are requirements.
> libcrypto.so.1 is needed by grass-5.3.0-1
probably due to PostGRESQL support?
> libdfftw.so.2 is needed by grass-5.3.0-1
Seems that I should defined that in the spec file.
> libexpat_ogdi31.so is needed by grass-5.3.0-1
Not desired: I didn't remember that I have built GDAL/OGR with
OGDI support on that machine for VMAP0 support.
> libgdal.so.1 is needed by grass-5.3.0-1
Aha, obviously libgdal needs to be defined separated. Or is it because
Iam using GDAL from CVS on that machine (not an RPM)?
> libgrass5.so.0 is needed by grass-5.3.0-1
Not desired: GDAL was built with GRASS support (for MapServer).
> libogdi31.so is needed by grass-5.3.0-1
Not desired: OGDI see above.
> libpq.so.3 is needed by grass-5.3.0-1
Desired: PostgreSQL support (7.3 on grass.itc.it).
> libproj.so.0 is needed by grass-5.3.0-1
Aha, obviously libproj wants to be defined separately?
> libssl.so.1 is needed by grass-5.3.0-1
I guess due to PostgreSQL support.
> libzlib_ogdi31.so is needed by grass-5.3.0-1
> IFF I understand correctly, this suggests that there are file/library
> dependencies that are not covered by the package dependencies, yes?
> Postgres, ssl, ... ?
I think so. Seems that
- I should insert more dependencies in the spec file.
- find a way to have two GDAL installations on the machine (suggestions
welcome!) - one with OGDI/GRASS and one "simple"
> Sorry if this is not useful...
Very useful! Thanks for the quick test!
Markus
Markus Neteler <neteler itc it> http://mpa.itc.it
ITC-irst - Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18 - 38050 Povo (Trento), Italy
