[GRASS5] 5.3-CVS: RPM created - please try
Glynn Clements glynn.clements at virgin.net
Fri May 14 06:18:12 EDT 2004
Markus Neteler wrote:
> >         libcrypto.so.1 is needed by grass-5.3.0-1
> probably due to PostGRESQL support?
This dependency is almost certainly bogus. The PostgreSQL modules
require libpq. If libpq happens to require libcrypto, then it is up to
the RPM which contains libpq to deal with that. GRASS shouldn't list
it as a dependency.
> >         libssl.so.1 is needed by grass-5.3.0-1
> I guess due to PostgreSQL support.
In which case, this is also bogus.
Glynn Clements <glynn.clements at virgin.net>
