[GRASS5] Problems with site data imported using v.in.ascii in G57
Radim Blazek blazek at itc.it
Fri May 21 04:47:55 EDT 2004
On Friday 21 May 2004 00:44, Funkmeister wrote:
> Hello, I am trying to import site data through v.in.ascii in G57. I can
> run the command:
> cat bdem-join.asc | awk  '{print $1 "|" $2 "|" $3 "|" $4}' | v.in.ascii
> out=bdem_sites xcol=2 ycol=3 catcol=1 columns='cat int, x real, y real,
> elevation int'
> and everything works nicely.
> When I try to display the map with d.vect i get:
> ERROR: Vector 'coor' format version 5.1 is not supported by this version
> of
>         GRASS. Update your GRASS.
> I am running 5.7 so I am not sure what's wrong here.
This should not happen, update and recompile GRASS from CVS.
Radim
PS: looking into diglib I found that the code checking versions was wrong
and I fixed it, but it was not causing the problem above.
