[GRASS5] Problems with site data imported using v.in.ascii in G57
Funkmeister
funkmeister at lynxseismicdata.com
Tue May 25 17:11:19 EDT 2004
Thanks Radim, I finally got source to recompile, and the sites file is
working fine now.
Craig
On 21-May-04, at 2:47 AM, Radim Blazek wrote:
> On Friday 21 May 2004 00:44, Funkmeister wrote:
>> Hello, I am trying to import site data through v.in.ascii in G57. I
>> can
>> run the command:
>> cat bdem-join.asc | awk '{print $1 "|" $2 "|" $3 "|" $4}' |
>> v.in.ascii
>> out=bdem_sites xcol=2 ycol=3 catcol=1 columns='cat int, x real, y
>> real,
>> elevation int'
>> and everything works nicely.
>> When I try to display the map with d.vect i get:
>> ERROR: Vector 'coor' format version 5.1 is not supported by this
>> version
>> of
>> GRASS. Update your GRASS.
>> I am running 5.7 so I am not sure what's wrong here.
> This should not happen, update and recompile GRASS from CVS.
> Radim
> PS: looking into diglib I found that the code checking versions was
> wrong
> and I fixed it, but it was not causing the problem above.
