[GRASS5] nviz problems
Helena
hmitaso at unity.ncsu.edu
Thu Nov 4 20:57:01 EST 2004
Hamish
I already discussed this issue with Markus but I did not follow up
on the list (as I am trying not to create too many distractions from 5.4 release).
Yes, nviz ALWAYS needs WIND3, even if you work just with 2D data.
It is needed to initialize the interface. It will be rather messy to have
it start differently for 2D and 3D data.
This is my suggestion (as there are and will be more modules that will require
3D region)
>Modify grass57 startup to check and ask for 3D region info.
> What I have in mind is that when you start grass57, it will check for
>WIND3 and if it is not there it will say e.g.:
>This GRASS release is a 3D GIS and requires 3D region definition, do you
>want to have it automatically created (you can later modify it using g3.region) ? y/n
> then the default WIND3 will just take the current region information
>and define WIND3 with 1 vertical layer.
>If it is done like this we don't have to worry about which module requires
>it and we don't need to implement this question into each such module
Markus, would you have time to implement this modified start-up?
After Paul is done with the release, I suggest that we also revisit the vertical
datum issue and creation of a new location under 5.7 as a 3D location with 3D window and
a coordinate system definition that includes both horizontal and vertical datums.
Helena
wrote:
>>>I have just updated the 57 CVS and I have just tried to start
>>>NVIZ... I have a problem because NVIZ doesn't start and I obtain
>>>this message:
>>>WARNING: G3d_readWindow: unable to find
>>> [//home/ivan/DATABASEGRASS/gauss_boagaEST/moreno/WIND3],
>>> using
>>>default.
>>>[//home/ivan/DATABASEGRASS/gauss_boagaEST/PERMANENT/DEFAULT_WIND3].
>>>FATAL ERROR: G3d_initDefaults: Error reading window
>>Use g3.createwind to create the WIND3 file. It shouldn't matter what
>>values you choose for the Z axis so long as you don't actually use the
>>G3D (3D voxel grids) features.
> This is a more general problem with the latest NVIZ vol updates.
> You get this error even if you do 'nviz -q' in a new mapset.
> Either we have to generate WIND3 files with each new mapset or
> (preferably) conditionalize the G3d_initDefaults() call for when it
> is really needed.
> Hamish
> grass5 mailing list
> grass5 at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass5
