[GRASS5] libgrass make error II
Tue Nov 9 09:58:21 EST 2004
Stefan Paulick wrote:
> libtool: ltconfig version `' does not match ltmain.sh version `1.3'
> Q: is to comment out - as suggested by Hamish
> (http://grass.itc.it/pipermail/grass5/2003-May/007848.html) - the
> official workaround or does both Redhat 8.0 and SUSE 9.1 require some
> additional setup?
> Q: does this matter:
> /libgrass/gis/Makefile.in Line 77: GRASS_SRC = /u/pkg/grass/src
Stefan,
Did you extract libgrass from CVS as opposed to using a packaged distribution?
The packaged distributions should be OK, but the CVS access results in an
attempt to rebuild various intermediate files and if your version doesn't
match the version originally used all sorts of hassles can result.
You might find the information on the following page helpful in forcing an
update of the libtool and other related intermediate files:
   http://people.debian.org/~keybuk/libtool-updating.html
Best regards,
