[GRASS5] [bug #2690] (grass) System Response when no colortable is present
Glynn Clements
glynn at gclements.plus.com
Mon Nov 15 18:19:22 EST 2004
Gordon Keith wrote:
> > If this isn't happening, file a bug report with details of how to
> > reproduce the problem.
> It happened to me the other day.
> v.in.ascii to get points data then v.to.rast to convert to a raster.
> There were some points that appeared (about 4 out of thousands).
> I was really wondering if v.to.rast actually works in 5.7 till I tried
> r.colors and it suddenly appeared.
That's a separate problem; v.to.rast explicitly sets a random
colourtable.
In the test cases I've tried, it seems to work ok. If you know of a
case which doesn't work, please submit a bug report with sufficient
details to allow reproduction.
