[GRASS5] [bug #2719] (grass) .grassrc57 syntax
Glynn Clements
glynn at gclements.plus.com
Thu Nov 25 06:35:34 EST 2004
Request Tracker wrote:
> this bug's URL: http://intevation.de/rt/webrt?serial_num=2719
> grass5.7.cvs-i686-pc-linux-gnu-24_11_2004/docs/html/variables.html:
> To permanently predefine GRASS variables the user may specify the
> variable(s) in the .grassrc57 file.
> OK, but also mention the syntax of that file and how to comment things out.
> Also mention if it is really just the user writing to that file, or
> are there other things writing to that file.
We shouldn't be recommending that the user manually modifies that
file. The official mechanism is to use g.gisenv.
