[GRASS5] Re: bugs in 5.7's tcltkgrass
Glynn Clements
glynn.clements at virgin.net
Fri Oct 15 09:55:33 EDT 2004
Michael Barton wrote:
> > 3. all modules I tried in 5.7 display this instead of percents only:
> > Percent complete: 2% 5% 8% (...) 100%
> On my computer, it goes:
> Percent complete: 2%/b/b/b/b5%/b/b/b and so forth...most of the time. Other
> times, it stops after a few increments, then does nothing until 100%
The prnout function in gui.tcl already tries to handle this, but
there's a bug:
--- gui.tcl~ Thu Oct 14 12:40:18 2004
+++ gui.tcl Fri Oct 15 14:46:59 2004
@@ -56,7 +56,7 @@
close $fh
} else {
set str [read $fh]
- while {[set idx [string first {\b} $str]] != -1} {
+ while {[set idx [string first "\b" $str]] != -1} {
set last [expr $idx - 1]
set str1 [string range $str 1 $last]
set first [expr $idx + 1]
Using quotes instead of braces results in the backspaces being
removed.
Glynn Clements <glynn.clements at virgin.net>
