[GRASS5] cvs2cl.pl: selection by date?
Markus Neteler
neteler at itc.it
Tue Aug 2 06:32:45 EDT 2005
On Mon, Aug 01, 2005 at 08:47:35PM +0200, Jan-Oliver Wagner wrote:
> On Mon, Aug 01, 2005 at 07:36:29PM +0200, Markus Neteler wrote:
> > I am trying to correctly generate the Changelog file for 6.0.1,
> > but have these troubles:
> > cvs2cl.pl -l "-d<'2005-10-03'"
> > cvs [log aborted]: Can't parse date/time: '2005-10-03'
> > Problem reading log input (pid/exit/signal/core: 22500/1/0/0)
> > cvs2cl.pl --version
> > cvs2cl.pl version 2.59; distributed under the GNU GPL.
> > cvs --version
> > Concurrent Versions System (CVS) 1.11.17 (client/server)
> > Any ideas? I googled around, but found no answer which worked.
> > Maybe it depends on the server version at Intevation?
> there was no change on the server, so if you successfully
> ran the same command before, it must be something else.
I am trying this the first time in my life :-)
> The error message says it can parse the date/time. Maybe
> your locale changed? (just a guess)
Yes, maybe it's related to the locale. but I have en_US.
> I have
> cvs2cl.pl version 1.174 (BETA); distributed under the GNU GPL.
> and it simple gives me an error message if I try the command
> you tried:
> $ cvs2cl.pl -l "-d<'2005-10-03'"
> sh: line 1: 2005-10-03: No such file or directory
I am using
## $Revision: 2.59 $
## $Date: 2005/05/18 05:34:34 $
## $Author: kfogel $
the latest...
Markus
> Best
> Jan
> Jan-Oliver Wagner http://intevation.de/~jan/
> Intevation GmbH http://intevation.de/
> Kolab Konsortium http://kolab-konsortium.de/
> FreeGIS http://freegis.org/
