[GRASS5] AW: [GRASS-de] problems compiling GRASS on SuSE 8.2
Marco Lechner
marco.lechner at geographie.uni-freiburg.de
Mon Feb 7 04:04:01 EST 2005
adding /usr/local/gdal/lib to /etc/ld.so.conf and run ldconfig solved the
problem
thanks
Marco
-----Ursprungliche Nachricht-----
Von: grass-de-bounces at grass-verein.de
[mailto:grass-de-bounces at grass-verein.de]Im Auftrag von Stephan Holl
Gesendet: Freitag, 4. Februar 2005 19:15
An: grass-de at grass-verein.de
Betreff: Re: [GRASS-de] problems compiling GRASS on SuSE 8.2
Hello Marco,
On Thu, 3 Feb 2005 14:26:40 +0100 "Marco Lechner"
<marco.lechner at urz.uni-heidelberg.de> wrote:
> Hi list,
> After hours of compiling with different options I still get this
> error-message after starting GRASS and having chosen the
> mapset/location:
> GRASS 6.0.0beta1:/usr/local/grass60/bin > Error in startup script:
> ps.map: error while loading shared libraries: libgdal.so.1: cannot
> open shared object file: No such file or directory
> while executing
> "exec ps.map -p"
> (procedure "DmPrint::init" line 14)
> invoked from within
> "DmPrint::init"
> (procedure "main" line 31)
> invoked from within
> "main $argc $argv"
> (file "/usr/local/grass60//grass-6.0.0beta1/etc/dm/d.m.tcl" line
> 890)
> but libgdal.so.1 is in /usr/local/gdal/lib/
> libgdal.la libgdal.so libgdal.so.1 libgdal.so.1.6.0
did you add /usr/local/gdal/lib to /etc/ld.so.conf and run ldconfig
afterwards?
This sets the path where the dynamic linker searches for libraries
loaded at runtime...
> A few more hints:
> I tried compilation with the GRASS 6.0.0beta1 and the CVS-Snapshot
> from Jan 25th. with the follwoing options:
> ./configure --with-cxx --with-odbc --with-blas
> --with-blas-libs=/usr/lib/ -
> -with-lapack --with-motif --with-readline --with-freetype=yes
> --with-freety pe-includes=/usr/include/freetype2 --with-mysql
> --with-mysql-includes=/usr/i nclude/mysql/ --with-nls
> --with-gdal=/usr/local/gdal/bin/gdal-config --with-
> postgres-includes=/usr/include/pgsql --with-postgres-libs=/lib/
> --with-proj- includes=/usr/local/proj/include/
> --with-proj-libs=/usr/local/proj/lib/ --wi th-glw
> --with-glw-libs=/usr/local/lib --with-glw-includes=/usr/local/include
> --enable-64bit --prefix=/usr/local/grass60./configure
> rass60/ --with-postgres-includes=/usr/include/pgsql/
fyi, you should remove the trailing slashes while configuring.
> configure works:
> GRASS is now configured for: i686-pc-linux-gnu
> Source directory: /nfs/u1/software/grass/grass-6.0.0beta1
> Build directory: /nfs/u1/software/grass/grass-6.0.0beta1
> Installation directory: /usr/local/grass60/grass-6.0.0beta1
> Startup script in directory: ${exec_prefix}/bin
> C compiler: gcc -g -O2
> C++ compiler: c++ -g -O2
> FORTRAN compiler:
> Building shared libraries: yes
> NVIZ: yes
> X11 support: yes
> JPEG support: yes
> TIFF support: yes
> PNG support: yes
> Tcl/Tk support: yes
> PostgreSQL support: yes
> MySQL support: yes
> OpenGL(R) support: yes
> ODBC support: yes
> FFTW support: yes
> BLAS support: yes
> LAPACK support: yes
AFAIK blas and lapack are currently used.
> Motif support: yes
> FreeType support: yes
> GLw support: yes
> NLS support: yes
> Readline support: yes
> C++ support: yes
> openDWG support: no
> GDAL support: yes
> OGR support: yes
> make has first problems in GRASS_SRC/lib/proj:
> GRASS GIS compilation log
> Started compilation: Thu Feb 3 14:00:52 CET 2005
> Errors in:
> /nfs/u1/software/grass/grass-6.0.0beta1/lib/proj
> Finished compilation: Thu Feb 3 14:08:56 CET 2005
> make in ...lib/proj says (no idea):
> saone:/u1/software/grass/grass-6.0.0beta1/lib/proj # make
> install -m 644 datum.csv gdal_datum.csv projop_wparm.csv ellipsoid.csv
> pcs.csv stateplane.csv gcs.csv prime_meridian.csv unit_of_measure.csv
> /nfs/u1/software/grass/grass-6.0.0beta1/dist.i686-pc-linux-gnu/etc/og
> r_csv
> if I start make again it works without errors:
> Started compilation: Thu Feb 3 14:17:34 CET 2005
> Errors in:
> Finished compilation: Thu Feb 3 14:18:14 CET 2005:
> make install goes without problems, but the message on top still
> apears.
HTH
Stephan
Stephan Holl
Check headers for GnuPG Key!
http://www.gdf-hannover.de
