[GRASS5] NVIZ Cutting planes
Bob Covill
bcovill at tekmap.ns.ca
Tue Jul 12 07:27:03 EDT 2005
Hi Stephan,
I think the color is drawn on only one side of the cutting plane. Try
using the rotate option to spin the cutting plane around, and the colors
should appear.
Not a perfect solution, but give it a try.
Bob Covill
Stephan Holl wrote:
> Dear list,
> I am trying to use the cutting-plane panel from nviz to create
> block-pictures. It works like it should especially the color-settings.
> Regarding to the manual the color can be chosen between top, bottom,
> blending, grey, no color.
> Grey and no color does work as it should, but the other parts (which
> are interesting for me) do not work...
> The planes still keep black, example here [1].
> Is there any mystery I need to know to make the color-options work?
> Thanks for any enlightments...
> Best
> Stephan Holl
> [1] http://www.gdf-hannover.de/holl/tmp/nviz_cutting_plane.png
