[GRASS5] [bug #3071] (grass) nviz: finer height panel step needed
Maciek Sieczka
werchowyna at pf.pl
Mon Mar 7 17:50:31 EST 2005
> Bob Covill bcovill at tekmap.ns.ca
> Sat, 05 Mar 2005 20:52:19 +0000
> Hello,
> As Hamish mentioned, the height scale and resolution are set automatically
> according to the data being loaded.
> The height min/max and resolution do get updated if a different value is
> entered. For example if a height is entered that is larger than the max of
> the scale it will automatically be updated to reflect the entered value.
> The same situation applies to the resolution. Try entering 0.5 for a new
> height. This should reset the height resolution to 0.5.
> Hope this helps.
Nope. I did like you wrote - entered height 0.5, pressed enter. Moving the
slider after shows it's still all the same - the height step is still
slightly over 100m (my elevation extent is 300-1600m). Could that be solved
one day maybe?
Maciek
