[GRASS5] [bug #3071] (grass) nviz: finer height panel step needed
Bob Covill
bcovill at tekmap.ns.ca
Mon Mar 7 19:16:04 EST 2005
With a height range of 300-1600m you may need to try a smaller number.
For example try entering 0.01 or even 0.001 and see what happens.
The initial resolution is set in widgets.tcl (nviz/scripts) and is set
by the (max-min)/140. You could try increasing the 140 to get a tighter
increment. Remember that the max/min is not the max/min from your raster
, but rather the max/min created at load time. This will always lie
outside of the data z extents. To check the initial max. min. slide the
height scale to the top and bottom respectively. The resolution should
be the difference of these two values divided by 140.
Probably what we need is a more dynamic resolution setting.
Hope this helps.
Bob Covill
>> Bob Covill bcovill at tekmap.ns.ca
>> Sat, 05 Mar 2005 20:52:19 +0000
>> Hello,
>> As Hamish mentioned, the height scale and resolution are set
>> automatically
>> according to the data being loaded.
>> The height min/max and resolution do get updated if a different value is
>> entered. For example if a height is entered that is larger than the
>> max of
>> the scale it will automatically be updated to reflect the entered value.
>> The same situation applies to the resolution. Try entering 0.5 for a new
>> height. This should reset the height resolution to 0.5.
>> Hope this helps.
> Nope. I did like you wrote - entered height 0.5, pressed enter. Moving
> the slider after shows it's still all the same - the height step is
> still slightly over 100m (my elevation extent is 300-1600m). Could that
> be solved one day maybe?
> Maciek
> grass5 mailing list
> grass5 at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass5
