[GRASS5] NVIZ freezing (?)
Stefan Paulick stefan.paulick at urbeli.com
Tue Mar 15 07:23:06 EST 2005
Setting "Grid Resolution" and Polygon Resolution to "1", NVIZ stops working
after one hour with the following message:
.		X connection to :0.0 broken (explicit kill or server shutdown).
When setting both  to "2", the screen is redrawn within a few seconds.
SuSE 9.1 Linux
Grid Size 1300x2300
1GB RAM on a 64bit CPU
X is using 70% fo CPU time, NVIZ 20%
no swap memory was requested
Manual says: "a resolution of 1 draws every raster cell in the current
region."
Question: Is this a resource or a algorithm problem?
Mit freundlichen Grüßen / With kindest regards
Stefan Paulick
http://www.urbeli.com
mailto://stefan.paulick@urbeli.com
