[GRASS5] v.in.ascii updates
Hamish
hamish_nospam at yahoo.com
Tue Mar 15 22:49:02 EST 2005
I'm looking to do some v.in.ascii updates, I thought I'd trawl for
comments first.. most deal with format=point mode.
Fairly straight forward updates:
+ update to use G_getl2() to make MacOS9 ascii import work.
+ add skip= option to skip any header lines when format=point
(e.g. column headings in cvs file)
+ add a -s flag to write those skipped header lines to the map's
meta-data hist file (v.info -h).
Debatable updates:
? skip any line starting with a '#' in input file.
(could silently ignore data..??)
? skip blank lines in input file.
(currently extra newlines at EOF break import of points)
? strip "quotes" from both ends of varchar input.
? rename format=standard to format=grass as format=point is default,
so standard mode is non-standard. Confusing! I'll fix any scripts/.
You can expect me to go ahead and do all these things if noone objects.
Hamish
