[GRASS5] d.vect.thematic on Mac OS X
Thomas Adams Thomas.Adams at noaa.gov
Fri May 20 14:07:20 EDT 2005
Michael,
I would like to play with d.vect.thematic. I have installed Lorenzo
Moretti's GRASS distribution for Mac OS X for both 5.4 & 6.0 and use
both. What do I need to do to try it out? Thanks for your help.
Regards,
Tom
Michael Barton wrote:
>If you want to change your local version, please go right ahead and see how
>it looks.
>Let's not change the cvs version until we have a consensus (if possible).
>For work in my field (archaeology) and from what I know of geography, the
>notation
>]min ; max]
>would be meaningless--although it might be perfect for your field
>Michael
>______________________________
>Michael Barton, Professor of Anthropology
>School of Human Evolution and Social Change
>Arizona State University
>Tempe, AZ  85287-2402
>USA
>voice: 480-965-6262; fax: 480-965-7671
>www: http://www.public.asu.edu/~cmbarton
>>From: Daniel Calvelo Aros <dcalvelo at minag.gob.pe>
>>Reply-To: <daniel.calvelo at minag.gob.pe>
>>Date: Fri, 20 May 2005 12:22:08 -0500
>>To: Michael Barton <michael.barton at asu.edu>, Maciek Sieczka
>><werchowyna at epf.pl>, Paolo Cavallini via RT <grass-bugs at intevation.de>
>>Cc: grass devel <grass5 at grass.itc.it>
>>Subject: Re: [GRASS5] Re: [bug #3246] (grass) d.vect.thematic fails when the
>>map is in another mapset
>>From: Michael Barton <michael.barton at asu.edu>
>>Sent: Fri, 20 May 2005 10:12:41 -0700
>>>I tend to agree with you that
>>>min - max
>>>looks better than
>>>>min - max
>>>although the second one is more accurate.
>>>What does everyone else think?
>>I'd like the math standard :
>>[min ; cut1]
>>]cut1 ; cut2]
>>]cutn ; max]
>>Note the *included* min. I'll see if I can put that into your current script,
>>Michael.
>>Daniel.
>_______________________________________________
>grass5 mailing list
>http://grass.itc.it/mailman/listinfo/grass5
Thomas E Adams
National Weather Service
Ohio River Forecast Center
1901 South State Route 134
Wilmington, OH 45177
EMAIL:	thomas.adams at noaa.gov
VOICE:	937-383-0528
FAX:	937-383-0033
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20050520/c754695c/attachment.html
