[GRASS5] [bug #3803] (grass) Can't start any monitor not even GUI
Michael Barton
michael.barton at asu.edu
Sun Nov 6 00:33:15 EST 2005
Anne,
This sounds like it may be missing the gdal library for some reason.
However, I strongly recommend that you use 6.1.cvs for Cygwin instead of
6.0. Ironically, the newest version of the "development" 6.1 (from Huidae
Cho's binary installation website) is much more robust, has more features,
and is easier to use than the "stable" 6.0.
You will need to delete 6.0 because there are conflicts between gdal (used
for importing and exporting graphic formats) for 6.0 and 6.1. Also, make
sure that you get the grass61.bat file to start it instead of the
grass60.bat file.
Michael
Michael Barton, Professor of Anthropology
School of Human Evolution and Social Change
Arizona State University
Tempe, AZ 85287-2402
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
> From: Request Tracker <grass-bugs at intevation.de>
> Reply-To: Request Tracker <grass-bugs at intevation.de>
> Date: Sat, 5 Nov 2005 19:26:55 +0100 (CET)
> To: <grass5 at grass.itc.it>
> Subject: [GRASS5] [bug #3803] (grass) Can't start any monitor not even GUI
> this bug's URL: http://intevation.de/rt/webrt?serial_num=3803
> Subject: Can't start any monitor not even GUI
> Hello!
> I downloaded GRASS 6.0.0, the recommended version, on my PC. It seems a
> problem of Cygwin, because GRASS works successfully until I write commands
> like d.mon ( it answers " no socket to connect to for monitor x0" ) or d.m &
> ( shows a short list of steps telling Application initialization failed: no
> display name and no $DISPLAY environment variable . Error in startup script:
> dynamic loading is not currently available on this system, then programming
> explanation.
> I wish you can help me, because I prefer GRASS to other (expensive!) GIS..
> is there, if Cygwin cold not be set right, another solution?
> Thanks
> Anne Ghisla
> -------------------------------------------- Managed by Request Tracker
