[GRASS5] [bug #3803] (grass) Can't start any monitor not even
GUI
Hamish
hamish_nospam at yahoo.com
Mon Nov 7 00:44:50 EST 2005
> this bug's URL: http://intevation.de/rt/webrt?serial_num=3803
> Subject: Can't start any monitor not even GUI
> Hello!
> I downloaded GRASS 6.0.0, the recommended version, on my PC. It seems
> a problem of Cygwin, because GRASS works successfully until I write
> commands like d.mon ( it answers " no socket to connect to for
> monitor x0" ) or d.m & ( shows a short list of steps telling
> Application initialization failed: no display name and no $DISPLAY
> environment variable . Error in startup script: dynamic loading is
> not currently available on this system, then programming explanation.
> I wish you can help me, because I prefer GRASS to other (expensive!)
> GIS.. is there, if Cygwin cold not be set right, another solution?
Sounds like X-windows isn't working correctly. Does something simple
like "xeyes" work? You need to get that working first.
Are you running from a DOS window or an Xterm? ie did you type "startx"?
Hamish
