[GRASS5] [bug #3809] (grass) Print display manager (to file)
does not print graphics (scale, grid)
Hamish
hamish_nospam at yahoo.com
Tue Nov 8 01:08:22 EST 2005
> this bug's URL: http://intevation.de/rt/webrt?serial_num=3809
> Subject: Print display manager (to file) does not print graphics
> (scale, grid)
> Clicking "print raster and vector maps using ps.map" with scale and/or
> grid on display and printing to file or paper does not produce scale
> or grid in printed product. This would be nice to have, as creating a
> or .xwd format does not produce satisfactory resolution for many
> report-printing jobs.
Use the ps.map "mapinfo" instruction for scale and bounds information
and the "scalebar" instruction to draw a scalebar. The "grid" and
"geogrid" instructions take care of the grids. It is hoped that the
print with ps.map button produces a command file template that gets
you close; you can then copy and tweak as needed.
> Also, "save diaplay to image file" using .png format produces vector
> components that are too small (i.e. thin lines, symbols and text too
> small).
maybe have d.out.png find and change any d.vect calls to use width=$res
? maybe not
Hamish
