[GRASS5] [bug #3826] (grass) two r.resamp.rst issues
Michael Barton
michael.barton at asu.edu
Sun Nov 13 14:27:50 EST 2005
Hamish,
We've run into that here too. One of my RA's did a test of interpolating to
a higher resolution using r.resamp.rst and the more complicated procedure of
generating a large number of points from a raster map, and then
interpolating from the points to a higher resolution.
r.resamp.rst is faster and more straightforward. BUT (a VERY big but), it
behaves exactly as you describe. It simply turns out a map that looks just
like the original map is subdivided into more grid cells, without any
interpolation. This makes the module essentially useless.
Michael
Michael Barton, Professor of Anthropology
School of Human Evolution and Social Change
Arizona State University
Tempe, AZ 85287-2402
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
> From: Request Tracker <grass-bugs at intevation.de>
> Reply-To: Request Tracker <grass-bugs at intevation.de>
> Date: Sat, 12 Nov 2005 13:37:05 +0100 (CET)
> To: <grass5 at grass.itc.it>
> Subject: [GRASS5] [bug #3826] (grass) two r.resamp.rst issues
> this bug's URL: http://intevation.de/rt/webrt?serial_num=3826
> Subject: two r.resamp.rst issues
> If you run r.resamp.rst at a resolution other that that of the input map, the
> output elev map is not created at the specified ew_res= and ns_res=
> resolution.
> A warning is given that you are doing so, but it doesn't mention why that
> might be bad. Interestingly the output map is actually written at the target
> resolution, but it contains the data resolution from the original map. (target
> was 50m, original was 100m)
> If the input map is in another mapset (map at othermapset) then it gives an error
> that the input map can't be found. (happens when it tries to copy the color
> table I think) and exits with an error. (but processing is already done so
> output map is ok, just without a colortable)
> Hamish
> ps - I've tidied up the module's code and strings a bit in CVS, so cvs update
> before fixing...
> -------------------------------------------- Managed by Request Tracker
