[GRASS5] [bug #3826] (grass) two r.resamp.rst issues
Jaro Hofierka hofierka at geomodel.sk
Sun Nov 13 17:20:06 EST 2005
Michael Barton wrote:
> Hamish,
> We've run into that here too. One of my RA's did a test of interpolating to
> a higher resolution using r.resamp.rst and the more complicated procedure of
> generating a large number of points from a raster map, and then
> interpolating from the points to a higher resolution.
> r.resamp.rst is faster and more straightforward. BUT (a VERY big but), it
> behaves exactly as you describe. It simply turns out a map that looks just
> like the original map is subdivided into more grid cells, without any
> interpolation. This makes the module essentially useless.
It's not useless because if you run the module at a resolution equal to
the input raster map, the result is OK.
The warning message should be replaced by a fatal error that exits the
command.
Jaro
> Michael
> __________________________________________
> Michael Barton, Professor of Anthropology
> School of Human Evolution and Social Change
> Arizona State University
> Tempe, AZ 85287-2402
> phone: 480-965-6213
> fax: 480-965-7671
> www: http://www.public.asu.edu/~cmbarton
>>From: Request Tracker <grass-bugs at intevation.de>
>>Reply-To: Request Tracker <grass-bugs at intevation.de>
>>Date: Sat, 12 Nov 2005 13:37:05 +0100 (CET)
>>To: <grass5 at grass.itc.it>
>>Subject: [GRASS5] [bug #3826] (grass) two r.resamp.rst issues
>>this bug's URL: http://intevation.de/rt/webrt?serial_num=3826
>>Subject: two r.resamp.rst issues
>>If you run r.resamp.rst at a resolution other that that of the input map, the
>>output elev map is not created at the specified ew_res= and ns_res=
>>resolution.
>>A warning is given that you are doing so, but it doesn't mention why that
>>might be bad. Interestingly the output map is actually written at the target
>>resolution, but it contains the data resolution from the original map. (target
>>was 50m, original was 100m)
>>If the input map is in another mapset (map at othermapset) then it gives an error
>>that the input map can't be found. (happens when it tries to copy the color
>>table I think) and exits with an error. (but processing is already done so
>>output map is ok, just without a colortable)
>>Hamish
>>ps - I've tidied up the module's code and strings a bit in CVS, so cvs update
>>before fixing...
>>-------------------------------------------- Managed by Request Tracker
> grass5 mailing list
> http://grass.itc.it/mailman/listinfo/grass5
