[GRASS5] SQL support/DB backends
Markus Neteler neteler at itc.it
Wed Nov 16 03:37:36 EST 2005
Daniel Calvelo wrote:
>Yup, you are both right. The point is that the documentation is
>supposed to be the grass sql parser documentation, which is currently
>only used for DBF. AFAICT it was supposed to be also used for textfile
>access, but there is no working txt driver now.
>The docs could state that those are the minimum SQL constructs that
>grass understands; anything fancier depends on the driver support.
>Getting the phrasing right might be tricky...
Maybe a native speaker is needed here? Or someone, who approximates a
native speaker
well...
Markus
