[GRASS5] r3.mapcalc doesn't work, isosurfaces
Joel Peter William Pitt
pittj2 at lincoln.ac.nz
Tue Nov 22 15:49:42 EST 2005
Okay, I got the latest CVS version and there are r3.to.rast and
r3.in.rast in there. They just don't get compiled by default because
they are not in the raster3d Makefile.
I've managed to get my timeseries into a r3 file. However things are a
bit buggy it seems.
Is the following supposed to work for volumes?
r3.mapcalc "test2=test"
At the moment any r3.mapcalc operations involving another r3 file seem
to result in a file full of nan's...
$ r3.info -r test
min=1.000000
max=1.000000
$ r3.info -r test2
min=nan
max=nan
Also, is the interpolation done by NVIZ on volumes able to handle
boolean values? Imagine a pyramid of value 1 surrounded by zero/null,
and occasional occurences of of cells equal to 1 outside of this
pyramid. I set a threshold of 1.0 on the volume in NVIZ but nothing
appears.... any ideas?
Thanks,
Joel
Helena Mitasova wrote:
> I will leave others to answer your NULL question (just another reason
> to start working on new raster map storage format for GRASS7).
> Regarding using 3d rasters for storing timeseries we need it badly for
> the simwe programs and I tried to convert an output of simulation to
> 3d raster using
> Soeren's r3.in.rast (I noticed it is not in GRASS CVS? - but you can
> get it from here:
> http://www-pool.math.tu-berlin.de/~soeren/grass/modules/) and then
> convert back using r3.to.rast for viewing, analysis etc.
> It works and if nothing else storing time series as 3d raster makes
> mapsets with multiple simulation runs much more manageable.
> It would be great if you could test whether it also takes much less
> space and how it would work with 3d mask.
> If it is indeed more space efficient, it may be worth to write few
> modules to work with such timeseries (e.g. extend xganim and
> r.out.mpeg to work with it, etc.).
> I would then make it an option to write the timeseries output of simwe
> programs either as 2d rasters or a 3d single file.
> Please, let me know whatever you find useful regarding to handling of
> timeseries in GRASS, it will help our work too,
> Helena
Joel Pitt, Room B534
Bio-Protection & Ecology Division
PO Box 84
Lincoln University 8150
New Zealand
PO Box 84
New Zealand
