[GRASS5] r3.mapcalc doesn't work, isosurfaces
Sören Gebbert
soerengebbert at gmx.de
Tue Nov 22 19:32:52 EST 2005
Hi.
On Tuesday 22 November 2005 21:49, Joel Peter William Pitt wrote:
> Okay, I got the latest CVS version and there are r3.to.rast and
> r3.in.rast in there. They just don't get compiled by default because
> they are not in the raster3d Makefile.
> I've managed to get my timeseries into a r3 file. However things are a
> bit buggy it seems.
Are there bugs in r3.in.rast? And if yes, what kind of bugs?
If there are bugs, i will try to fix them.
I know that in r3.to.rast the NULL handling was wrong, but
that was fixed some days ago in the CVS.
> Is the following supposed to work for volumes?
> r3.mapcalc "test2=test"
> At the moment any r3.mapcalc operations involving another r3 file seem
> to result in a file full of nan's...
> $ r3.info -r test
> min=1.000000
> max=1.000000
> $ r3.info -r test2
> min=nan
> max=nan
I have no problems.
Mapset <data> in Location <slovakia3d>GRASS 6.1.cvs > r3.in.rast input=dem500 at PERMANENT output=dem3d
Open raster map dem500 at PERMANENT
Creating 3D raster map
100%
100%
100%
100%
100%
100%
Mapset <data> in Location <slovakia3d>GRASS 6.1.cvs > r3.info -r dem3d
min=0.000000
max=2230.092041
Mapset <data> in Location <slovakia3d>GRASS 6.1.cvs > r3.mapcalc "test = dem3d"
100%
Mapset <data> in Location <slovakia3d>GRASS 6.1.cvs > r3.info -r test
min=0.000000
max=2230.092041
What kind of maps (floar or double) and projection are you using? Are you using a mask?
I know that there are some problems with mask support in 3d maps.
> Also, is the interpolation done by NVIZ on volumes able to handle
> boolean values? Imagine a pyramid of value 1 surrounded by zero/null,
> and occasional occurences of of cells equal to 1 outside of this
> pyramid. I set a threshold of 1.0 on the volume in NVIZ but nothing
> appears.... any ideas?
nope.
> Thanks,
> Joel
> Helena Mitasova wrote:
> > I will leave others to answer your NULL question (just another reason
> > to start working on new raster map storage format for GRASS7).
> > Regarding using 3d rasters for storing timeseries we need it badly for
> > the simwe programs and I tried to convert an output of simulation to
> > 3d raster using
> > Soeren's r3.in.rast (I noticed it is not in GRASS CVS? - but you can
> > get it from here:
> > http://www-pool.math.tu-berlin.de/~soeren/grass/modules/) and then
> > convert back using r3.to.rast for viewing, analysis etc.
> > It works and if nothing else storing time series as 3d raster makes
> > mapsets with multiple simulation runs much more manageable.
> > It would be great if you could test whether it also takes much less
> > space and how it would work with 3d mask.
> > If it is indeed more space efficient, it may be worth to write few
> > modules to work with such timeseries (e.g. extend xganim and
> > r.out.mpeg to work with it, etc.).
> > I would then make it an option to write the timeseries output of simwe
> > programs either as 2d rasters or a 3d single file.
> > Please, let me know whatever you find useful regarding to handling of
> > timeseries in GRASS, it will help our work too,
> > Helena
> Joel Pitt, Room B534
> Bio-Protection & Ecology Division
> PO Box 84
> Lincoln University 8150
> New Zealand
