[GRASS5] imagery sample data has duplicate case-sensitive filenames
William Kyngesburye
woklist at kyngchaos.com
Wed Nov 23 16:49:28 EST 2005
(Not sure if it's OK to use the bug report form for a sample data
issue, so I'll just use the list)
In the IMAGERY GRASS 5 and 6 sample data, there are files named
'GROUP' and folders named 'group' at the same folder level, as well
as 'SUBGROUP' and 'subgroup'. This does not work on a case-
insensitive (tho case-aware) file system such as HFS+ as is used in
Mac OS X.
I believe GROUP is the old method that is now CURGROUP (changed in
GRASS 5). and similar for SUBGROUP.
Depending how the tarballs are expanded, a Mac user may be able to
get something usable:
StuffIt Expander (v7): error, get nothing
Tiger BOMArchiveHelper (double-click): stops expanding at that error
TAR in Terminal: error but keeps going - you get the folders, but not
the duplicate files (assuming the files sort after the folders in the
tarball)
William Kyngesburye <kyngchaos at kyngchaos.com>
http://www.kyngchaos.com/
Earth: "Mostly harmless"
- revised entry in the HitchHiker's Guide to the Galaxy
