[GRASS5] Swig interface for Grass
Markus Neteler
neteler at itc.it
Thu Nov 24 10:43:31 EST 2005
Sajith VK wrote:
>Does it indicates that adding python binding to grass
>will be more easy? I like it!.
Yes, I guess so.
>I can try to implement that (I am already using a small
>python binding for grass library which includes only
>few functions which are needed for me). If you are
>already working for the python-binding,
>count me for testing.
As far as I know nobody is working on it at the moment. So you are welcome!
>Grass must cross all boundaries... Languages, Toolkits,
>platforms....all
Absolutely!
Markus
>On 11/23/05, Markus Neteler <neteler at itc.it> wrote:
>>Hi,
>>I have added draft 'doxygen' style documentation of the
>>new SWIG interface in CVS (swig/index.dox).
>>For a version in HTML, see here:
>> http://mpa.itc.it/markus/grass61progman/swig/GRASS_SWIG_interface.html
>>SWIG may help to use GRASS as GIS backbone in other applications,
>>be local, be WebGIS.
>>Markus
