[GRASS5] timeseries: null file, r3
Helena Mitasova
hmitaso at unity.ncsu.edu
Thu Nov 24 16:31:17 EST 2005
> Glynn,
> can you implement this change so that it gets into the next release,
> if there are no objections?
> I have always thought that 0 as NULL has been gone with GRASS4,
> I find it pretty confusing (even in GRASS4* it has always caused all
> kinds of problems).
> I work almost exclusively with FP maps so I did not realize
> that this behavior is still there.
> thank you,
> Helena
> On Nov 23, 2005, at 12:54 PM, Glynn Clements wrote:
>> Joel Peter William Pitt wrote:
>>> I need to store many thousands of maps for different model simulation
>>> runs as each has at least 25 maps in a timeseries.
>>> Currently running 100 replications of a 25 year model on a 2000x2000
>>> region results in about 2.1 gig.
>>> This on its own is okay, but I need to run sensitivity analyses on a
>>> range of parameters, meaning each value I test for a parameter gives
>>> a
>>> location of 2.1 gig!
>>> Checking out the actual data files however shows that the cell files
>>> are
>>> only about 60k each. The problem is the uncompressed null bitmasks
>>> that
>>> are 700k each. Now, I can explicitly remove the null bitmask using
>>> "r.null -r", but I was wondering if the null mask will just get
>>> automatically created next time I run a GRASS command?
>> The null file is created when the map is created, or via r.null.
>>> Also, I'm under the impression that if there is no null bitmask then
>>> values equal to 0 in the cell file are interpreted as nulls, is this
>>> right?
>> For integer maps, yes. If a FP map doesn't have a null bitmap, all
>> cells are valid.
>> This is for compatibility with 4.3, which didn't have null bitmaps. It
>> didn't have FP maps either, so compatibility isn't an issue there.
>> This behaviour could easily be removed; see the following code in
>> get_null_value_row_nomask() in lib/gis/get_row.c:
>> if (read_null_bits(null_fd, fcb->null_work_buf,
>> i+fcb->min_null_row, fcb->cellhd.cols, fd) < 0)
>> if (fcb->map_type == CELL_TYPE)
>> If can't read null row, assume that all map 0's are nulls
>> use allocated G__.mask_buf to read map row */
>> get_map_row_nomask(fd, (void *) G__.mask_buf,
>> CELL_TYPE);
>> for (j = 0; j < G__.window.cols; j++)
>> if (G__.mask_buf[j] == 0)
>> flags[j] = 1;
>> else
>> flags[j] = 0;
>> else /* fp map */
>> /* if can't read null row, assume that all data is valid */
>> G_zero(flags, sizeof(char) * G__.window.cols);
>> /* the flags row is ready now */
>> } /*if no null file */
>> To disable the behaviour, replace the above block with:
>> 4.3 is old enough that we could probably just remove that behaviour
>> altogether. It just requires anyone using maps which were created
>> using 4.3 to add a null bitmap with r.null.
>>> Is there anyway to specify NOT creating a null mask when creating a
>>> map?
>> No.
>> Glynn Clements <glynn at gclements.plus.com>
>> grass5 mailing list
>> grass5 at grass.itc.it
>> http://grass.itc.it/mailman/listinfo/grass5
> Helena Mitasova
> Dept. of Marine, Earth and Atm. Sciences
> 1125 Jordan Hall, NCSU Box 8208,
> Raleigh NC 27695
> http://skagit.meas.ncsu.edu/~helena/
Helena Mitasova
Raleigh NC 27695
