[GRASS5] [bug #3859] (grass) raster file access problems in
GRASS6.1.cvs
Michael Barton
michael.barton at asu.edu
Thu Nov 24 23:11:49 EST 2005
I received an error trying to reply to Paolo via RT. So I'm just resending
to the list.
Michael
Michael Barton, Professor of Anthropology
School of Human Evolution and Social Change
Arizona State University
Tempe, AZ 85287-2402
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
> From: Michael Barton <michael.barton at asu.edu>
> Date: Thu, 24 Nov 2005 21:10:24 -0700
> To: Paolo Cavallini via RT <grass-bugs at intevation.de>, <grass5 at grass.itc.it>
> Conversation: [GRASS5] [bug #3859] (grass) raster file access problems in
> GRASS6.1.cvs
> Subject: Re: [GRASS5] [bug #3859] (grass) raster file access problems in
> GRASS6.1.cvs
> It may or may not be related, but r.flow stopped working on Fedora Core 4 a
> couple weeks back. It gives incorrect errors about resolution settings and/or
> hangs. We did a bug report but I don't remember the number.
> Michael
> phone: 480-965-6213
> fax: 480-965-7671
>> From: Request Tracker <grass-bugs at intevation.de>
>> Reply-To: Request Tracker <grass-bugs at intevation.de>
>> Date: Wed, 23 Nov 2005 23:02:52 +0100 (CET)
>> To: <grass5 at grass.itc.it>
>> Subject: [GRASS5] [bug #3859] (grass) raster file access problems in
>> GRASS6.1.cvs
>> this bug's URL: http://intevation.de/rt/webrt?serial_num=3859
>> Subject: raster file access problems in GRASS6.1.cvs
>> Platform: GNU/Linux/i386
>> grass obtained from: Trento Italy site
>> grass binary for platform: Downloaded precompiled Binaries
>> GRASS Version: GRASS6.1.cvs-19_11_2005
>> This is an addendum to bug report #3808, but I list it here as a new report
>> as
>> it involved more functions than just d.rast.
>> I downloaded precompiled version of GRASS61.cvs-19_11_2005 to further test
>> issue with d.rast as described in earlier report. No other changes to
>> operating system, and GRASS-6.0.1 continues to operate just fine.
>> Having had more time to experiment, I have found that more raster commands
>> appear to not function in cvs.6.1 - it's as if the raster files cannot be
>> read
>> (also created?) for some reason. For example, r.calculator does not write any
>> files, r.buffer appears to "stall" when reading the input file, etc.
>> Curiously
>> though, other commands such as r.colors and others, appear to work fine
>> (files
>> altered in 6.1 and read in 6.0.1, as d.rast in cvs.6.1 still does not work).
>> This does not appear to be an environment issue, as vector files can be read
>> and viewed just fine. Any suggestions, as I like the changes made to GRASS in
>> cvs.6.1 and would like to make greater use of it both for regular use, and as
>> contribution to the development effort by testing (which I cannot do withoug
>> raster functions).
>> Regards,
>> Rick
>> -------------------------------------------- Managed by Request Tracker
