[GRASS5] QGIS GRASS Shell (hell)
Jachym Cepicky jachym.cepicky at centrum.cz
Fri Oct 14 03:34:57 EDT 2005
hallo,
it seems to be working. will it support $GRASS_ADDON_PATH in the future?
system: debian - testing.
how is it? is grass going towards Qgis or Qgis towards GRASS ;-) ?
I would like to ask, how is it with the new mapcalculator? There is map
called "Output", when I try to perform calculation
|  0   +--------+ Output |
Is resulting to
r.mapcalc =(0)
syntax error, unexpected '=', expecting NAME or STRING
Parse error
Finished with error
Hot to set the name of the output map?
Jachym
On Thu, Oct 13, 2005 at 06:59:56PM +0200, Radim Blazek wrote:
> Hi,
> I added shell to GRASS tools in QGIS:
> http://mpa.itc.it/radim/qgis/shell1.png
> It is very simple pseudoterminal implementing limited
> subset of VT100 control characters and sequences.
> There is no support for pseudoterminal in Qt, so it starts
> in C: seteuid, openpty, fork, execl, fchown, fchmod, etc.
> which certainly appreciate all Qt/OOP/C++ fans.
> openpty is in libutil (on Linux), so I added check to configure
> and ifdef in code for openpty. Other functions should be POSIX.
> It does not support vertical moving => impossible to run programs
> printing on the whole screen like  mc, top etc.
> It is very probable that you will find some problems with your
> shell/distro/settings combination, please report important unsupported
> control sequences.
> I am not sure if we can get working without problems in all enviroments,
> note that konsole has 19000 lines and I don't want to reimplement/include it.
> Links: http://vt100.net/docs/vt100-ug/
> Tom, could you find the openpty on Mac and try to compile?
> Radim
> grass5 mailing list
> grass5 at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass5
Jachym Cepicky
e-mail: jachym.cepicky at centrum.cz
URL: http://les-ejk.cz
GPG: http://les-ejk.cz/gnupg_public_key/
OFFICE:
Department of Geoinformation Technologies
LDF MZLU v Brně
Zemědělská 3
613 00 Brno
e-mail: xcepicky at node.mendelu.cz
URL:    http://mapserver.mendelu.cz
Tel.:   +420 545 134 514
