[GRASS5] [bug #3758] (grass) v.in.e00 deletes files it did not create
Request Tracker
grass-bugs at intevation.de
Fri Oct 21 18:30:14 EDT 2005
this bug's URL: http://intevation.de/rt/webrt?serial_num=3758
Subject: v.in.e00 deletes files it did not create
Platform: GNU/Linux/i386
grass obtained from: Other (CDROM etc)
grass binary for platform: Downloaded precompiled Binaries
GRASS Version: 6.0.0
If you run v.in.e00 in a directory that contains another directory named info it will recursively delete the info directory as it trys to clean up after itself. It seems like if would be better to create temporary files in a tmp directory rather than the working directory.
This bug effects versions of GRASS available from Debian Etch as well as the Mac OS X builds at http://wwwamb.bologna.enea.it/forgrass/
-------------------------------------------- Managed by Request Tracker
